- Bagman3605ExplorerThanks to all for the info
- darsbenExplorer IIMy guess is fuel pump getting to hot. If you search you will find that some models had issues with the fuel pump overheating and causing a vapor lock type situation. The cure people found was to move it off the motor and mount somewhere else where it is not subject to direct engine heat.
Sorry I cannot find the threads right now - joloooteExplorerPin holes or crack in the fuel line sucking air.
- Pirate1ExplorerFuel pump.
