Ltrip
Jun 04, 2017Explorer
Mine is doing the same thing. I suspected the fuel pump. When the gen quit, I opened the carb drain and pressed the prime button. No fuel. Later when the gen would start, i shut it down before it quit on its own. I repeated the above and fuel came through.
So, I have a new fuel pump, fuel filter on order.
I anticipate that this will fix it. If not, on to the next possibility, which may require expert help.
A friend of mine had the exact same problem, and this solution solved his problem.
Good luck! Is your under warrantee?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
