waterfowlhunter's avatar
May 21, 2016
Onan 6.5RV 3CR-16020P Generator Battery charging?
Does the 6.5 RV 3CR-16020P have a built in Battery Charger? The reason I am asking is that if I disconnect the battery the generator shuts off. My Kohler Generator only needs the battery to start and will run fine without it.
Also is there a procedure to check / adjust the choke? My choke has a wire to it so I assume it is electric and it also has a manual lever you can move. It never moves on its own it is always about 1/4 on.
1 Reply
  • No Onan RV Genset has a built in charger. The choke should move if you move that wire. the wire should be loose to move and not rigid. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
