185EZ's avatar
185EZ
Onan 7000 sputtering on start up
nothing to see here
  • RLS7201 wrote:
    I would try bending the pull-off linkage a little to make it more active. Just make sure the choke will still fully shut when cold.
    Richard
    That did it.
    Choke fully closes.
    Only weird thing was the choke plate flops around a lot on first start up
    2nd start up it stayed in place with choke pull off
    No sputtering or black soot coming out.
  • I have a 7K Onan Marquis Gold in my 95 Bounder. The carb was not initially "throw away". I purchased a float and needle kit from Onan in 2004, because of a cracked plastic float. It has worked very well for the last 14 years. It's not a junk carb.
    Richard
  • Ha! yes it is Marquis Gold
    As in gold carburetor
    Seems like a simple design vs carbs on motorcycles and such
    Not sure why they have to be so finicky.
  • 185EZ, if this is a Marquis Gold, it is one of Onan's famous "throwaway" carbs. Just plain junk!
  • Thanks.
    I was wondering if I did something wrong during the cleaning.
    It was fine before i messed with it lol
    I've heard these are throw away carbs and you can't even get a rebuild kit
  • I would try bending the pull-off linkage a little to make it more active. Just make sure the choke will still fully shut when cold.
    Richard
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 02, 2026
