kmb1966ExplorerJan 21, 2016Onan carburetor float has fuel inside of floatMy Onan Marquis Gold 7000 will run for about 15 seconds and then appears to flood out and die. Took carburetor off, removed the bowl, and the float itself is full of fuel. I'm thinking that is the p...Show More
TEXASExplorerJan 21, 2016kmb1966 wrote:update: Looks like no kit available. Float is plastic. ordered a new carburetor from ASAP onlineDon't know who told you no kit available. Float kits are all over the place.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
Related Contentcarburetor float failureReplace insulation inside heater column.Lifepo4 float setting?Honda EU2000i carburetor rebuild kitFlying Floating Flooring
