- midnightsadieExplorer IIif its a brass float? find the hole and fix it. I,ve resoldered car floats when I was a kid.
kmb1966 wrote:
Yes if you can get one.
Can I just replace the float?
Any damaged gaskets during disassembly should be replaced so you may as well get a kit.- K_CharlesExplorerYes, just adj the hight of the new one when you install it.
- Chris_BryantExplorer III believe most of the 2 cylinder carbs do have kits available- you might look around at ASAP for a kit.
Having RV issues? Connect with others who have been in your shoes.24,295 PostsLatest Activity: Aug 05, 2025
