Rambler's avatar
Rambler
Explorer II
Oct 25, 2012
Onan Gen
Have a Onan marquess gold gen
At gen just above the breaker switch there is a white switch (no toggle just slide)
Was wondering if anyone knows what this slide left to right switch is?
Couldn't find in Manuel.
Also no start from inside switch but starts from outside fine.
Any suggestions?
2001 Pace Arrow Vision
Thanks
  • I have had this remote start problem with two different Onan gensets. Both times the problem was with the remote switch wiring, not the switch. This wiring runs to a "molex" type connector that plugs in to the side of the genset switch housing.
    First, look for corrosion of the pins in the connector (squeeze the ears and pull gently to unplug) and clean as required; also while the connector is disconnected, ensure that all the wires are properly crimped to the pins in the connector. Correct any issues if found and then reconnect and try to start remotely.
    Second, both of my gensets were supplied with only about 12" of wire on the connector and the OEM supplied the wiring to the dash. These wires were spliced using crimp-type connectors which were hidden inside the plastic wire loom. Find the splices and inspect carefully; this circuit usually works by connecting the start circuit all the way from the gen set to the dash and back again so it MUST be a low resistance connection. One (or more)is very likely corroded. Re-splice if necessary and try to start remotely.
    I hope this helps.
  • Switch on dash should just have four plastic spring like tabs 2 on top and 2 on bottom that can be compressed to pop out of dash. Use a thin blade maybe to push them down a little from front of switch. I found a wire Diagram if you can not find one or get one from others here.
    Good Luck,
    DJ
  • Fleetwood99,
    Yes this is my generator.
    I have sprayed with contact cleaner and no change.
    I think it may be the switch on dash that is bad. Having a difficult time
    trying to disconnect wiring from switch. Would like to know how switch comes out of dash.
    I have taken many wiring harnesses off of switch prior but this one is a problem.
    Also tech from onan said to unplug wiring connector at generator and look back into wiring covering. Could be wire come apart about 6 inches in harness covering.
    Still on the investigation of why its not working. It shuts off proper from remote switch, just won't start.
    Thanks for any help
    Rambler
  • I have tried to spray connection cleaner on big connector from remote switch on dash.
    Anyone know how to remove dash switch? 2001 Pace Arrow Vision
    Tried again but didn't work, just seems dead on start side. But I can use stop side and it works well?
    Any other ideas of what to check out?
    I see two white wires with yellow/gold color insulators on inside left bottom of genie housing.
    Tried to wiggle them loose but they seem very tight? Didn't force them as not sure what they are.
    Onan Marquis Gold 5500 Gas Generator
    Thanks
    Rambler
  • Just started from inside switch one time so I am going to try spraying contact cleaner on my connections for next step.
    Thanks again for the advice.
    Rambler
  • The slide switch is Circuit breaker also
    Will continue checking harness connections
    Thanks for reply
    Rambler
  • I don't know about the switch but you don't have a good connection somewhere in your remote harness . If you can post a picture of the slide switch or email it we might could get it figured out.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 08, 2026
