the_bear_II
May 31, 2013Explorer
There should be a bypass switch that allows you to switch from the power cord for power to the generator for power. Once this is switched to generator power or auto standby then you will have power when the generator is running.
In addition there are circuit breakers on the generator, you need to make sure they haven't been turned off or tripped. Your generator manual will show the location.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
