fred42's avatar
fred42
Onan generator fuel filter replaced with a fitting
I'm usually the last one to figure things like this out, but I thought I would pass it along anyway since it is a safety issue.
I acquired this 2007 Allegro last year. I have changed the generator oil, oil filter and air filter. It has 200 hours on it. The manual does not give instructions on changing the fuel filter as it says "must be performed by a qualified mechanic (authorized Onan dealer)". It suggests at 450 hours. This is probably just standard Lawyer text as I assume many of you have changed the fuel filter yourself?
It is not due, unless years count, but it has a very slight gas leak. It could be from the clamp area or it could be coming down from what I assume is the fuel filter attach ring which usually has an O-ring if it is like my tractor. The hose does not have a lot of play but probably enough to make a fresh clamp area.
Underneath there is the generator fuel pump and what appears to be another filter.
When looking for the filter part, I could not find it in the Onan diagrams as it has been replaced with just a fitting.
On Amazon, one reviewer referred to the original redundant filter as dangerous. I guess that is why mine is dripping gas. Maybe there had been a recall?
https://www.amazon.com/CUMMINS-NW-ONAN-REPL-FITTING/dp/B00BFU52XO
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
