jeffo's avatar
jeffo
Onan Generator wil not Prime
I have a 2013 Onan 5500 gas generator. I was going to exercise it today and when I hit the prime I cannot hear the pump running. It turns over fine but will not start. I assume it not getting any gas. Not sure if the pump you hear when you prime is the fuel pump that also feeds the carb after it is started. I checked all the wires that I can see, all look fine. Not sure where the primer pump is? It ran fine last month and the gas tank is full.
  • I checked the voltage to the pump and I am getting 14.5 when the rocker switch is in the prime position. I read somewhere to tap the pump with a screw driver handle but it did not work. I guess I will replace the pump.
  • Is a Bendix type pump that sort of chatters until it builds pressure? Crack a line and check for pressure.
  • Its a small diaphragm type pump. It is not making any sound at all now, You can normally near it from inside the RV. An Onan pump is 94.00 and a Airtex pump is 38.00. I think I will try the Airtex It is very easy to change if it does not last. However they get good reviews.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
