YC_1
Jul 07, 2016Nomad
Ok, I found a schematic and here is what might associate the two issues. If one of the mating plugs is not working both the light and the meter may indeed not run. You can use the diagram I provided and see if there is voltage on the pins the bulb is associated with. IF you see voltage on both sides of the bulb then the ground is not working. Go to the plugs that lie along the side of the generator and exercise them by finding the little lock and disconnect and reconnect them.
