Clay_L
Jan 24, 2016Explorer
joebedford wrote:
I ordered the parts online to do a tune up on my generator. The description of the fuel filter says that if you have one near the carb to replace it with a fitting. I'm pretty certain that the questionable item by my carb is already a fitting not a filter.
Thanks for the help.
Yes it is. The filter on the fuel pump is the newer filter that replaced the older one that had a smaller diameter and was longer. The fitting in the second picture is the adapter that replaced the old second filter when they started using just the one filter on the pump.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
