- MrWizardModeratorMoved from technology
- eHoeflerExplorer IIBoth will run at the same RPM, this is how you get your cycles in A/C current. You will get a more powerful engine and 1K. Generally, it takes 2 HP for every 1000 watts. Better to go bigger and not need than to be running at max all the time.
5500 watt gives you 25 amps/220 volts
6500 watt gives you 29.5 amps/220 volts
on each leg
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
