ford_truck_guy's avatar
May 01, 2016
Onan install... 5.5 or 6.5
I have been quoted to have an Onan 5.5 installed in my genny compartment... What are the pro's and con's of a 6.5 - vs - 5.5 ?
Is the extra KW's and rpm worth the $800.00 up charge?
  • Both will run at the same RPM, this is how you get your cycles in A/C current. You will get a more powerful engine and 1K. Generally, it takes 2 HP for every 1000 watts. Better to go bigger and not need than to be running at max all the time.
    5500 watt gives you 25 amps/220 volts
    6500 watt gives you 29.5 amps/220 volts
    on each leg
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
