Gjac
May 05, 2022Explorer III
You said than no fuel is getting to the generator. Did you verify this by disconnecting the fuel line to the carburetor and turning over engine and seeing if any fuel squirts out? If nothing comes out, I would insert the fuel pick up line into a gal of gas and do the same thing. If no fuel comes out check the fuel pump. This of course assumes your fuel level is high enough to reach the pickup tube. Gas in your mouth will tell you that as someone has already suggested.
