jltarley's avatar
jltarley
Onan microlite 2800 Gas Carburetors
I've recently purchased a 1988 RV with an Onan KV spec J 2.8 gasoline. I was able to get the generator running, but it runs rough, and surges very strongly. All research leads me to believe that the carb needs replaced.
The carb in the generator is P# 146-0861. I've had a hard time finding a replacement for less than $300, and there just does not seem to be a lot of them out there. I have been able to find quite a few 146-0569 carbs, which are from previous versions of the same model gen.
Are these carburetors interchangeable? If not, does anyone have any other good solutions for this issue?
  • j-d's avatar
    j-d
    Explorer II
    I found This 146-0705
    that claims it works up to Spec J
    An expert told me awhile ago that Microlite (KV, KY) carbs are very difficult to clean because of right angle turns in some of the passages.
    If you can get it running, load it down, and feed it from a gallon can of fresh gas that's dosed heavy with Berryman cleaner. Run it a couple hours, let it rest while the Berryman soaks in, run again, repeat...
  • j-d wrote:
    I found ***Link Removed***
    Thanks for the info. Where did you see that it fits to Spec J?
  • j-d's avatar
    j-d
    Explorer II
    I'm sorry. Dyslexic besides, apparently. YOU have Spec J. The eBay listing says "beginning Spec E" which I took as OK. Open the link then click "Details" and scroll down for the "E" claim. There's also a California number to call. This ad and part number was the first hit I got. Looking further, there are other ads with slightly lower price and some with free shipping. You might get a break of $25 or so.
    If you go to do this remove/replace job, it's easy and I have a few tips. Changed ours on a KY, and the machines appear similar. KY is 4KW and KV is 2.8KW.
