Nov 22, 2021Explorer II
Measure the battery voltage in 2 steps
1st while trying to start it, measure the battery voltage while touching the battery posts. Touch only the lead posts with the probes. The battery voltage dropped to what voltage?
2nd while trying to start it, measure the voltage at the cable connectors connected to the battery. Only touch the cables. If you have exposed copper cable, measure there. That will test the crimp. What did the voltage drop to?
Is there a voltage difference between the 2 measurements?
