GPSTECH
Sep 15, 2014Explorer
Onan Microquiet 4000 "No Crank"
My Onan will not crank. When pushing the button you hear the fuel pump kick in and the light flashes fast and constant. When you push the stop button you again hear the fuel pump kick in.
Again this is a no crank condition, not a cranks and wont start.
I jumped across the solenoid and it cranks but wont start unless I hold the start button or the stop button down. Then it will start and run as long as you hold the button down. Of course if you hold it down in the start position too long it will shut off and give you the over crank code. It will run as long as I want holding the stop button down but does not produce 120v while holding the button down.
Any ideas?
Any ideas?
