2Gordons
Jul 24, 2014Explorer
Onan Starter Quit
Hey All:
A couple of questions about my on-board propane powered Onan genset in my 1995 Lance... it is the Microlite 2800 series.
There is a remote start rocker switch on the control panel in the camper, and a start rocker switch on the genset itself, in the compartment.
I was trying to start it today after changing out an empty propane cylinder. After several starts and stops as the air was purged, the start switch stopped working. I tried the one in the camper... no worky either. I checked the circuit breakers, and replaced the 5-amp fuse on the genset control panel. I am not finding any other fuses on the panels, under the cabinets, or on the converter that would account for this. Battery is fully charged.
The generator was working fine yesterday, as I checked it when I pulled the unit out of storage, until the right tank ran out. After switching tanks over, it fired right up.
Any thoughts as to what else I can check? Even if there was a propane delivery problem, the starter should cycle, unless that circuit has gone bad somehow, or the starter-motor itself has failed. Any other ideas on what to check?
Does anyone know how complicated this repair might be, if it's the starter motor itself?
FWIW, we normally use our Honda 2000, as this Onan has proved remarkably unreliable. If Honda made a replacement that would run on propane, and fit into the space this Onan takes, I'd buy it tomorrow.
Any thoughts much appreciated. Thanks,
Don
Don
