bukweet53's avatar
bukweet53
Onan5500 won't run
After having intermittent shutdowns and code 2. After changing oil it will only run if I pull wire off oil pressure switch. On a recent trip it shutdown a few times throwing code 2 even after adding oil. Shutdowns at different times and days.
  • When you change the oil, prefill the oil filter before you screw it on.
    Sam
  • So took wire off switch and it cranked up. Ran it for two hours no problem. Let it cool down and checked oil, it was a little below the full mark. Hooked wire up an it fired up and ran just fine. Maybe just a bubble and needed a good fart... running fine now.Thanks everyone !!
  • jdc1 wrote:
    Grit dog wrote:
    First blush is bad oil pressure switch.
    Agreed. It's $10 part. Worth trying before paying someone to look at it.
    Or low oil pressure, which would be easily diagnosed by throwing the (cheap) part at it first.
  • Onan Generator Blink Code 101
    Onan Generator Fault Code List
    Code 2 - Low Oil Pressure
    Code 3 - Service Check
    Code 4 - Over Crank
    Code 12 - Over Voltage
    Code 13 - Under Voltage
    Code 14 - Over Frequency
    Code 15 - Under Frequency
    Code 19 - Governor Actuator Overload
    Code 23 - Low Oil Pressure Cutoff Switch
    Code 27 - Voltage Sense Error
    Code 29 - High Battery Voltage
    Code 31 – Overspeed
    Code 32 - Low Cranking Speed
    Code 35 - Control Card Failure
    Code 36 - Engine Stopped
    Code 37 - Invalid Generator Set Configuration
    Code 38 - Over Current (Field Overload)
    Code 41 - Generator Rotor
    Code 42 – Processor
    Code 43- Processor Fault Code.
    Code 45 - Speed Sense
    Code 47 – Ignition
    Code 48 - Generator Field Sense
    Code 51 – Processor
    Code 52 - Fuel Injector
    Code 54 - MAT Sender
    Code 56 - MAP Sender
    Code 57 - Over Prime
    Code 58 - Exhaust Gas Temperature Shutdown
    Code 81 - Exhaust Gas Temperature Sensor Open
    Code 82 - Exhaust Gas Temperature Shorted
    Onan Generator Code Reset
    Some Final Words
  • jdc1's avatar
    jdc1
    Explorer II
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
