mrekim's avatar
mrekim
One Metal Valve Stem Solution
I have aluminum rims with a recessed hole for the valve stem. I've read about people not being able to find metal valve stems that work. Here's a photo of mine:
I wanted to add a TMPS and generally wanted to convert to metal valve stems.
I found these:
They seem like they will work well in my case. These are Haltec N-1600 valve stems. Here's their description:
Ford “F" Series Trucks with Dual Wheels
Alcoa Aluminum 16"
Front & Rear Wheels
Chrome Finish
.453
The metal washer/spacer od is ~1.5 cm.
The height from the rubber grommet to the top of the valve stem is ~3.3 cm.
The diameter of the end that goes inside the tire is ~1.7 cm.
I torqued to 25 INCH lbs and that seemed to hold air on the 1st try.
Hopefully this will help others who are having problems finding metal valve stems.
No RepliesBe the first to reply
