bacabunch's avatar
bacabunch
Onion/egg smell from hot water.
Not sure if this is the right forum, but I could use your help. I got a bad smell when running the hot water. This is what I have done so far.
Drain fresh water and and hot water tank.
Filled with fresh water and bleach.
Anything further to do?
Thanks,
Ben
  • I have the same problem with one cold water line running to my bathroom basin. This has been a continuous problem since the first year I bought my fiver. I have bleached the system and bleached only that particular line and the problem returns in a couple of weeks. It is getting to the point that I am going to try and replace that cold water line and the basin faucet to see if that will fix it for good.
  • most of that was leftovers from the anode. A friend had one that fell apart and clogged all his hot faucets, not just the aerators. He had to replace them both.
  • Our local RV repair facility recommended a wand for the end of a hose. Remove the drain plug and wash out all the sediment from the bottom of the heater tank. Fixed our problem!
  • It can also be caused by water with some sulfur content.
    The following is from the Atwood service manual:
    "1. Turn off your main water supply. Drain your water
    heater tank. Reinstall drain plug. Remove the
    pressure-temperature relief valve. With a funnel
    use 4 parts white vinegar to two parts water. (In a
    6 gallon tank that would be 4 gallons vinegar to 2
    gallons water).
    2. Cycle the water heater, letting it run under normal
    operation 4-5 times. At no time do you remove the
    vinegar from the tank Once this has been
    completed, remove the drain plug and drain the
    water heater.
    3. After thoroughly draining the tank, to remove the
    sediment, flush the water heater.
    If you elect to use air pressure, it may be applied
    either through the inlet or outlet on the rear of the
    tank or applied through the pressure-temperature
    relief valve. Remove the pressure-temperature
    relief valve and insert your air pressure through
    the pressure-temperature relief valve coupling. In
    either case, with the drain valve open, the air
    pressure will force the remaining water out of the
    unit.
    If air pressure is unavailable, your unit can be
    flushed with fresh water. Fresh water should be
    pumped into the tank either with the onboard
    pump or external water pressure. External
    pressure may be hosed into the unit either
    through the inlet or outlet found on the rear of the
    tank or the pressure-temperature relief valve
    coupling located on the front of the unit.
    Continue this flushing process for approximately
    five minutes allowing ample time for the fresh
    water to agitate the stagnant water on the
    bottom of the tank and forcing the deposits
    through the drain opening.
    4. Upon completion of the steps above, replace the
    drain plug and the pressure-temperature relief
    valve.
    5. Refill tank with fresh water that contains no
    sulphur."
  • Anything further to do?
    Hi Ben,
    The rotten egg smell is caused by bacteria reacting with the anode in the HW tank. Both aluminum and magnesium can cause this odor... If cleaning with chlorine bleach or hydrogen peroxide doesn't solve the problem, then switch to an aluminum/zinc anode.
    Cheers,
    -Mark
  • If you have an anode rod and it is magnesium it could be reacting with the water that you are using. An aluminum rod would help that. Otherwise as stated above...flush...
  • I drain my hw tank between trips if it's going to be more than a couple of weeks. I drain the fw tank too.
    I've never had a problem with the water quality in my tanks.
    Mitch
  • Well, besides flushing the system. Other than that, you probably got it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
