Old-Biscuit
Jul 31, 2014Explorer III
When you 'checked all my breakers...everything seemed fine'--how did you check them?
Did you turn them to OFF and then reset back to ON?
Also.......check the wires on breaker and make sure they are tight/making good contact.
And you might look around for another GFCI outlet.....check if tripped.
Tripped GFCIs, tripped circuit breakers, loose wire on breaker AND one other possibility.
A loose wire in an outlet upstream of those that aren't working. Requires identifying the suspect outlet....pulling it and checking the wires for proper connections.
RV outlets are cheap design.....they use a split-prong that the wires clip/push into vs hardwired/screwed or even a good push contact like residential outlets.
They wire the outlets in a daisy chain string..if wire works loose (easy to do) then all outlets downstream stop working.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
