MEXICOWANDERER
Aug 03, 2014Explorer
Problem solving tip. Have power indicated on a non contact voltage tester but whatever that line powers does not work?
Continue on to the device(s) powered up but not working. Follow the "other" wire the neutral wire. The voltage tester will keep beeping! It should be playing possum.
There is a break in that neutral wire. Keep following it and you'll find your broken bad connection.
Hope this helps
Hope this helps
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
