Ruck
Nov 21, 2014Explorer
Ruck wrote:To bridge over a sag like that, you need something with an autoformer built into it. Of course those are the most expensive type...
I don't have one but I'm sure someone here could recommend a good one.
CG owner said he had a problem similar to it on another site, next door, a bit ago, and the camper had a pro look at it and it was the breaker, will change it first and see what happens, thank you!
Breaker! 50amp GE, has solved the problem, so far everything is working as it should... (fingers crossed) Thank you all for the input!!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
