MEXICOWANDERER wrote:
Never seen a trailer connector that isolated the front clearance lights. Not even a TTMA 9-way connector does that. If he has taul lights and running lights and amber red lit across the rear this is a.harness connection issue. If the problem isn't at the string it's at where the string connects at the tail running lights junction.
Sorry your giving wrong info here, they DO split off the top two orange running lights in the pin box junction. I found that out after fishing for the blue brake light wire to connect my electric/hydraulic pump needed for my disc brake install.
Found a set of wires going UP under the front cap and couldn't figure out what they where until I disconnected them.
Maybe not all campers have it this way but mine certain did. And I'm guessing the majority of Keystone products might have it this way too.
Ron W.
