eieioh's avatar
eieioh
Oven door handle replacement
We have a 2003 winnebago minnie. The oven door handle has broken. It is a Master Chef unit. I can find the part listed on the web page. But, they say "no longer available". Any suggestions from the experienced experts? Please?!?
  • I have a 2003 FW with amana stove. Same problem. Lots of web search and a few phone calls. My handle is WP(whirlpool) part#74003929. DISCONTINUED. Inside end of handle had another part #, but it is installed now after the 4 pieces were super glued together and can't be seen. I found a appliance drawer handle at Home depot. Internet #306069910, Model BP55323BBR, Amerock Highland Ridge for $112.00. If you do the measurements, drill 2 holes, it will cover the old holes. The front facing of the door can removed with removal of 2 screws at top and 2 on bottom of door. That's my backup when the glue no longer holds. The WP handle fits a lot of stove models.
  • If you can find a replacement handle, be prepared to have a spare set of hands available to help with the reassembly. You have to take the oven door apart to remove/install the handle attaching screws. Installing the lift springs and tensioning them while setting the door in position will try your patience. They must have a special jig (which I don't have) to help them with the initial assembly at the factory. I suggest you install some flat washers to help add some strength/rigidity to the handle/door stiffness so the handle/sheet metal wont bend in the future when it gets leaned on. (which it will)
    Chum lee
  • Enter the model number on Google with the word "parts" and see what comes up.
  • DrewE's avatar
    DrewE
    Explorer III
    Assuming this is just a bar across the front and not some latch mechanism or similar, it seems it wouldn't be too tricky to come up with a usable alternative. Maybe assemble bits and pieces of pipe? Maybe find an appliance handle (or other cabinet handle) with the appropriate spacing? Maybe a towel bas could be used--often they can be trimmed to length?
    Another good option is to enquire of RV salvage yards.
