Gjac's avatar
Gjac
Explorer III
Mar 05, 2015
Over cooling a Norcold Refer
I have an 18 year old Norcld 682IM refer that did not come with cooling fans. It works fine at 85 degrees or less but struggles to maintain 40 degrees inside the refer on 90 plus days. After reading many post about installing an external fan or fans in the back I installed a bilge pump fan(fan in the can) that moves a lot of air. It seems to make the refer run hotter when turned on. So my question is can you have too much cooling? I noticed one guy had 4 fans and he reported much lower refer temps at 90 plus degrees outside. Is there an optimal temp for the cooling tubes?
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
