bhivetravels
Jan 07, 2014Explorer
Overhead bed spot lights out, side lights too
I've done the preliminaries: fuzes OK, breakers OK no other lights affected just the two directly over the head of the bed (2 small spots), and two side lights next to the pillows controlled by one switch. I've pulled each light to check the wires and check for power - wires OK, no power. I've not taken the switch apart because from the look of the switch, it appears to be just a snap in and it's either in or not? The issue started with a burnt bulb. Removed old bulb, replaced with new - then no power. Again I've checked GFIs, fuzes, and each of the four lights for loose wires and power. None and no. My thoughts are: another wire behind the headboard or in the ceiling? Wire on the back of the switch? Any other ideas before I start tearing things apart and the DW really gets aggravated at the additional mess I've made!
