ajriding
May 20, 2019Explorer II
Haha, yes, TC's typically have little water tanks.
I adjusted my water pump to put out the least amount of pressure. There is a Phillips screw on top of the motor, outside that can be turned. When on low psi setting it runs half-a-second repeatedly instead of one big surge and long pause. The water tends to surge from weak to weaker, but I use less water.
I will even go so far to get my wash cloth wet under the sink, soap it up before turning the shower head on. Seems like wetting the wash cloth under the shower head spray waste more water.
Maybe we need a water-saving thread….
I have not seen shower heads that are adjustable for gpm. They exist?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
