StewB
Sep 15, 2013Explorer
Pairing Eu2000's
Anyone know if you can pair up a Canadian Eu2000 with an American Eu2000 companion?
I know Canadian Eu2000's cannot be paired.
StewB wrote:Not if you intend on using the parallel banana plug connector.. wink wink.
StewB wrote:
Robert, can a Canadian EU2000 be retro fitted with the parrell ports if on is not worried about CSA?
Wayne Dohnal wrote:the Floating Neutral IS the reason that you can not get a parallel kit and CA models do not come with the ports- it dos not comply to CA electrical codes.Has to be more to it than that in light of the eu1000iKC2 supporting parallel operation.
Wayne Dohnal wrote:I believe that the reason is that the Canadian ones have one leg bonded to the frame as a grounded neutral and the U.S. ones have both legs floating.The Canadian eu2000i does not have a bonded neutral. See this post http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27040043/gotomsg/27047098.cfm#27047098, then scroll down 3 posts for a picture of the Canadian eu2000i panel that says "Neutral Floating" and "Neutre Flottant".
