- WalabyExplorer III don't know what they run, they just look cool.
Mike jdc1 wrote:
Devocamper wrote:
Boon Docker wrote:
I tell them that the panels don't run things. They charge the batteries which in turn run the 12 volt items and the inverter.
Same here ,it’s surprising how often this happen and how many people do not understand solar at all.
You should hear what solar homeowners have to experience. Paying nothing for electricity doesn't seem like a good thing to 90% of the nation.
Stating that Solar Homeowners pay nothing is like stating your Tesla cost NOTHING also. People forget you had to spend 75k and up for the Tesla and up to 50k for a fully functional Home Solar system. Lets take 25k for a home solar system. My electric bill for my 3400 sq foot house(VERY energy efficient) runs $1500 per year. How many years would it take to recoup my 25k COST????? And what happens if I MOVE? Doug- 2oldmanExplorer II
jdc1 wrote:
I would imagine that's because they don't have the upfront investment.
Paying nothing for electricity doesn't seem like a good thing to 90% of the nation. - jdc1Explorer II
You should hear what solar homeowners have to experience. Paying nothing for electricity doesn't seem like a good thing to 90% of the nation. - DevocamperExplorer
Same here ,it’s surprising how often this happen and how many people do not understand solar at all. - 12thgenusaExplorerThe correct answer is they "run" everything. When the panels are producing power, any loads (as opposed to battery charging) on the system are first supplied by the panels to the limit of their capability with any remainder going to battery charging if they are not full. If a load is placed on the system greater than can be supplied by the panels, the batteries make up the difference with no charging taking place during that time (obviously).
On average my panels send about 60 to 70 percent of the power they produce in a day to the batteries and the remainder to directly power systems. - maillemakerExplorer
I guess that's why I see so many dry campers running generators.
Generators are easy to understand. Solar, batteries, inverter.. not so much.
The main reason is that barring a mechanical malfunction or running out of gas, generators just work, all the time, any time. Night or day, under trees or not, the generator always provides electricity. Push a button - bam - you've got 110V juice.
Solar Panels would be useful if you were truly doing long-term, off-the-grid living. But I only boodock in my RV for longer than a weekend about once every 2 years. I run out of water way before I run out of gas for the genny. Heck I run out of water before I deplete my batteries. - LScamperExplorerBFL13 is exactly correct.
The answer to the question of what happens to all that solar output when there are no other loads is the same thing that happens to all that power coming from your 120 volt wall outlet when nothing is plugged in. - Boon_DockerExplorer IIIx2 - 2oldman
No need to confuse them more than they already are. - 2oldmanExplorer II
BFL13 wrote:
Yes, we all know this, but try explaining all that to someone who asks that question. They won't even know what a controller is.
The charge controller like the converter, does 12v loads first and anything left over goes to the battery if the battery wants any.
When someone asks the question I get the impression they think you just plug something in to a solar panel.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
