- 2oldmanExplorer III think next time I'll just say 'my TV' or something like that. If there are no further questions, I'll consider it answered.
- DarkSkySeekerExplorer
DrewE wrote:
The fact that the power is temporarily stored in a battery is likely not all that relevant
Agreed - Johno02ExplorerI try to be nice, and explain things to those who are looking for knowledge, but sometimes its difficult.
- Johno02ExplorerRecommend wind power... Free charging as you drive!! Got my popcorn ready!!
- LwiddisExplorer II"I guess that's why I see so many dry campers running generators. Generators are easy to understand. Solar, batteries, inverter.. not so much."
Many older people have "checked out," "mentally retired" and are not interested in any different way to recharge their batteries that requires learning, thinking, planning and implementing. Sometimes the cause is some level of dementia and sometimes it is laziness. - MDKMDKExplorer
DrewE wrote:
A helpful (but not too extended) reply could be something like "over the course of a sunny day, they generate about 2 kWh of energy, which is enough to power my fridge and television and lights" or whatever the details may be for you and your solar setup. The power does ultimately come from the solar panels, after all.
The fact that the power is temporarily stored in a battery is likely not all that relevant in answering the casual question; it's just a detail of the implementation. If you ask the city how much water the municipal pump station supplies, you likely wouldn't care or need to know that it actually gets pumped to a water tower and the tower supplies the water to the city. Of course if they're thinking of putting together their own solar energy system (or you're setting out to design a large scale water supply system) then such details are well worth delving into.
Another thoughtful way of dealing with the question at hand. - DrewEExplorer IIA helpful (but not too extended) reply could be something like "over the course of a sunny day, they generate about 2 kWh of energy, which is enough to power my fridge and television and lights" or whatever the details may be for you and your solar setup. The power does ultimately come from the solar panels, after all.
The fact that the power is temporarily stored in a battery is likely not all that relevant in answering the casual question; it's just a detail of the implementation. If you ask the city how much water the municipal pump station supplies, you likely wouldn't care or need to know that it actually gets pumped to a water tower and the tower supplies the water to the city. Of course if they're thinking of putting together their own solar energy system (or you're setting out to design a large scale water supply system) then such details are well worth delving into. - MDKMDKExplorerMy revised answer has become, "it depends", although I like pianotuna's response, as well.
- 2oldmanExplorer III guess that's why I see so many dry campers running generators.
Generators are easy to understand. Solar, batteries, inverter.. not so much. - DarkSkySeekerExplorer
Lantley wrote:
True understanding is when one can communicate an idea to someone outside of their circle.
Excellent point - for me, requires patience.
Having RV issues? Connect with others who have been in your shoes.24,291 PostsLatest Activity: Jul 28, 2025
