Salvo wrote:
The somewhat higher voltage panels the OP chose are not that bad for his application.  He'll be in an hot environment where voltage headroom is easily lost.
I only boondock on or near the coast where it's much cooler but this is good to know. At home, I just need it to maintain a float charge.
landyacht318 wrote:
I guess if adding panels is an option, then making it easy to add panels is paramount. A Junction box wired to the charge controller with oversize wire, will make add-ons simpler, and more likely to occur.
I plan to put a combiner box on the roof in case I want to add more panels. Not sure if I want #10 or #8 from the box to the controller (or maybe even #6).
BFL, I WAS thinking of stealing PT's idea of stacking panels. The upper panel would be fixed and the lower panel would slide out. I could put the lower panel on bottom mount drawer slides (I'm using bottom mount, heavy duty drawer slides on my battery tray). I'd probably need a 4" L bracket for the top panel.
