Camping_Hoosier's avatar
Sep 11, 2013
Parallax Power Supply 7345
Hi folks
I have a 2006 Jayco Eagle and the original IOTA power supply has given up the ghost. I'm looking at replacing it this weekend with a Parallax 7345 that I'm ordering from Amazon.com.
I see that they have the 7355 (55 amp) for $10 more. Is there any advantage for me to go ahead and get the 55 amp over the 45 amp?
Thanx
  • The Parallax 7345 is a single stage converter. It supplies a constant 13.8 volts. At that voltage it charges batteries very slowly and once charged it boils the water in the battery.
    It is much better to replace your old converter with a PD 4600 converter. It will charge your battery much faster and then when charged it provides a voltage of 13.2 volts that keeps the battery charged without boiling it. It also provides desulfication of the battery.
    As far as the 45 vs 55 A it depends on how many batteries you have. If you have 2 or more the 55A will charge the batteries a little faster.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
