Extra info on the complex part:
-the total amps cannot exceed the battery acceptance rate amps.
If your battery will accept 60 amps at that SOC and voltage, you can put two 40 ampers on it and each will do 30 amps (or if they are at different charger voltages, some combo where the higher voltage one does more amps than the other but the total cannot exceed 60 due to the battery acceptance limit.  Might see 40 and 20 instead of 30 and 30.
-once the battery acceptance is down to 40 amps, instead of leaving the two 40s doing 20 each, you can yank one 40 and the other will jump back to its full 40 and go on from there tapering as usual.
-each charger has its voltage 'spread' between its voltage and the battery's.  As the battery voltage rises, the spreads get smaller. Once the spread gets really small, that charger's amps will taper then stop as the spread gets down to zero.  So that charger is 'squeezed out' and the others which still have some spread continue.  Eventually, as each charger's spread shrinks to zip and it drops out, the last charger (the one with the highest charger voltage) will be doing it all.  When its spread is gone, no amps flow, and the battery is fully charged
So just because two chargers are "adding their amps" it doesn't mean each one is putting its full rated amps into the battery.  You can only get all chargers doing full amps and see the total of that, when
all chargers still have enough 'spread' to be at full amps, and the battery will accept all those amps from all those chargers.
It works best when all chargers are at close to the same charger voltage and that is high 14s.
There is no point in running more chargers when a smaller number of chargers can do all the amps the battery will accept.
-Sometimes one charger won't start if the other one is already on.  If that happens, start them in the opposite order.  Now most likely, the second one will start so you get both running.  You might have to do some trial and error on that for the chargers you happen to be using until you figure out which to start first.  Rule of thumb for common case-- start the smart portable first, then cut in your converter and solar.
Between two smart portables, start the lower voltage one first.  I found the 14.6v Vector 35 amp 1092A would not start if the 14.8v, 40 amp VEC1093DBD was already on.  Turn on the 14.6 one first and the 14.8 one starts no trouble and you get 75 amps total showing on the Trimetric.   It takes a little practice to learn how to get them all going sometimes.
