Salvo
Oct 05, 2014Explorer
The two supplies will share current when they are in current limit. That means setting both supplies to 15.5V or what ever when battery is discharged. You will get 40A.
If you set the supplies to 14.4V and when the battery reaches that voltage the supplies will switch from current mode to voltage mode. When in voltage mode, power supplies do not share current well. The higher voltage supply will back bias the other supply. Depending on the cable resistance, you may get something from the lower voltage supply.
I think it's a lot easier to get a 40A supply than to constantly baby sit the voltage adjust to get them to share.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
