jrnymn7
Oct 05, 2014Explorer
"When in voltage mode, power supplies do not share current well. The higher voltage supply will back bias the other supply. Depending on the cable resistance, you may get something from the lower voltage supply."
Yes, this is the inherent issue with trying to parallel psu's, and this is why it was recommended to use one in c.v. and the other in c.c.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
