ken_white
Oct 06, 2014Explorer
jrnymn7 wrote:
??? could any small variations in voltage output of either unit cause the other to drop out prematurely?
And do I simply set both units to 20a c.c., and let their voltage rise as needed to supply the 20 amps each?
thanks.
Yes and Yes.
Constant current paralleled is fairly easy for load sharing and straight forward.
Constant voltage is not, since the feedback loops may cause instability (oscillations) in the output voltage between the two supplies and load - even when Schottky diodes are used in series between the supply and load...
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
