BFL13
Oct 06, 2014Explorer II
What does setting the 20a do? Is it just the max current limitation, such as my Vector which can be 40 or 20 or 10 or 4 as the max current, or is it some special deal where it will maintain 20a by raising its voltage to prevent tapering?
If it is just a max current limit setting, then it is the same as me using two Vectors (same voltage) both set at 20a, which will act exactly the same as if I used one Vector set at 40a. (except the two Vectors will have a tiny difference in voltage so their amps will be a tiny bit different, but close enough)
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
