ken_white
Oct 06, 2014Explorer
BFL13 wrote:
What does setting the 20a do? Is it just the max current limitation, such as my Vector which can be 40 or 20 or 10 or 4 as the max current, or is it some special deal where it will maintain 20a by raising its voltage to prevent tapering?
If it is just a max current limit setting, then it is the same as me using two Vectors (same voltage) both set at 20a, which will act exactly the same as if I used one Vector set at 40a. (except the two Vectors will have a tiny difference in voltage so their amps will be a tiny bit different, but close enough)
Some power supplies have a constant current setting which means the output voltage can assume any voltage level within the specified range while producing a fixed current value.
You are talking about setting a current limit which protects the power supply.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
