ken_white
Oct 06, 2014Explorer
Once the power supply is out of the current limit range, the battery is nearing a voltage level that cannot take that much charge, the voltage will become constant and the current will vary.
If one power supply is set at a slightly higher voltage than the other, the one with the higher voltage setting will deliver more current while the supply with the lower voltage setting will deliver less or none.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
