jrnymn7
Oct 06, 2014Explorer
Here's what the manual says concerning parallel:
"Units of identical nominal output voltage can be connected in parallel in order to gain a higher total output current. It is recommended to adjust the output current to the maximum and the output voltage to identical value on every unit.
So there it is. But it still does not explain how cc and cv are activated? Nor does it explain what would happen if you did not set the A to max.?
And if I do end up paralleling two of these, I think I'll do the two into one wiring, just to be safe.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
