jrnymn7
Oct 06, 2014Explorer
BFL wrote:
"Ok, I am only used to chargers (not necessarily the same as "power supplies" ?) which have a voltage limit and are current limited so they do constant amps until they go to more of a constant voltage at their voltage limits and amps then taper."
Salvo wrote:
"A thirsty battery puts the ps in cc mode. The ps is the slave. All the ps does is regulate current. A not so thirsty battery puts the ps in cv mode."
...So it's really no different than a so-called smart charger! Just re-branded, re-purposed, pre-set psu's...(Sneaky buggers).
And so I imagine, when Amps are pre-set, and locked in to cc mode (this unit has a lock feature, as well), and one applies it to an already full battery, it sorta "tricks" the psu into seeing the batt as 'thirsty', and holds amps steady while volts rise.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
