LScamper
Nov 03, 2014Explorer
Yet another stability paper. About the same as the one Salvo noted.
It shows how to measure stability in a CLOSED LOOP system. You do not have to open the loop. It injects a stimulus into the loop. Is this the same as injecting a stimulus as in connecting another power supply in parallel? I think so. As long as the stimulus is not so big that it causes the loop to saturate it seems it should work.
http://www.edn.com/design/power-management/4412230/Testing-a-power-supply---Stability--Part-three-
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
