jrnymn7
Nov 24, 2014Explorer
Salvo wrote:
Some folks have problems reading the fine print. You can parallel power supplies in voltage mode as long as the supplies regulated voltage difference is less than the power cable line drop. They will however not share equally.
Salvo, are you referring to the ac line input to the psu? If so, how does one go about equalizing ac line voltage?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
