BFL13
Sep 10, 2018Explorer II
You must have a shunt to know those amp numbers. That means you cannot just disconnect the batts and still have solar.
+For storage, you must disconnect the shunt to batt neg post wire, disconnect the solar neg from the other end of that shunt, and connect that solar neg to the battery neg. That will cut off all the draws from the rig and you still get solar. Put it back the other way for going camping.
Having RV issues? Connect with others who have been in your shoes.24,358 PostsLatest Activity: Feb 05, 2026
