CA_Traveler
Mar 07, 2022Explorer III
ilandgreen wrote:
After holding the battery boost switch, all goes back to normal, sometimes for 5 minutes other times an hour or two. If the generator is on it rarely happens if even at all.
Sure sounds like a discharged house battery while driving. A voltmeter is your friend.
Thinking logically if it was a fuse, the problem wouldn't be intermittent, would it?
No
Could the inverter have been damaged from the short and is causing this?
Doesn't seem to be the charger since the problem doesn't occur with the gen running which would charge the house battery with the charger.
