- Tom_NExplorer
thmitch79 wrote:
Not only will I not raise the tires off the ground when parking, I will not allow a garage to use my jacks to remove a tire. Got into an argument when I went to get new tires. If the shop doesn't have the proper equipment to raise the chassis, then go somewhere else.
I lift my front wheels off the ground when my truck garage greases my kingpins. - thmitch79ExplorerNot only will I not raise the tires off the ground when parking, I will not allow a garage to use my jacks to remove a tire. Got into an argument when I went to get new tires. If the shop doesn't have the proper equipment to raise the chassis, then go somewhere else.
- anon125Explorerthanks all
wondered just how tough the levelers were. - Tom_NExplorerI do it if needed to level and have been since 2002.
- wilanddijExplorerMost of the sites at Monterey County (CA) fairgrounds are steep enough that I have to park with front wheels off the ground. Have stayed there many times without any problems. Front wheels - OK, rear wheels - never (that's where the parking brake meets the road).
- Bill_SatelliteExplorer IIFeeling and doing are very different. You CAN lift the front wheels WITHOUT issue.
- Dutch_12078Explorer IIIMy Bigfoot jacks are rated for 12,000 lbs each. That's 48,000 lbs of lifting capacity holding up a coach with an 18,000 lb GVWR if all the wheels are off the ground. No, I don't worry about the occasional need to have one or both front wheels off the ground to get level.
- Pop-Pop_CExplorerI drive up on blocks. Under no uncertain terms raise any of the wheels off the ground.
I feel fully extending will cause problems!!!!!! - MaverickBBDExplorerI have done it on occasion without damage. Any longer then an overnight I would use my boards that I made for such instances. Never the rear wheels. Again, have boards I can drive up on.
- anon125Explorerthanks for help with the A class situation
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
