NinerBikes
Oct 02, 2015Explorer
icanon wrote:
Ok
Here is the specs the new 75W solar panel:
Up to 75Watts
Open circuit volt. 21.5v
Max power volts. 17.1v
Short circuit current. 4.3A
Actual results tested at noon, direct sunlight was:
21.5v
3.69A
So to me everything is fine? So does that mean I can expect an average of around 2.0A/hour during summer day time? Am I correct to think that?
State of charge of your battery will affect also how much output the solar panel makes. Low state of charge, the panel will put out more amps, because the battery can accept it. As it gets closer to being topped off in state of charge, the less the panels output will be for charging rate.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
